tiedyemike8 said:
But if the instant center is too far back, wouldn't the rear of the car try to jump off the ground at launch, throwing everything out of whack and probably resulting in a lot of wheelspin?
That's Antisquat.
I hope I get this right as I'm mostly going from memory, but here goes [-o<
Depending on the car, you can increase traction by increasing
or decreasing antisquat. Too much AS hits the tires really hard, but only on lauch. Then as the suspension sets, the ires may spin. Not enough AS makes the rear droop on launch & unloads the suspension, also causing tire spin right off.
When you raise the front of the top you're increasing the IC, but not correctly. You're moving the IC up above the Center of Gravity, too. This increases Percentage of Rise.You have to move all 4 mounts, top & bottom to increase IC without changing the PR. more PR "hits" the tires harder, less PR hits softer.
I'm sure there's stuff to read & diagrams to help you visualize on the internet, but I don't have time to search here at work.
