Relocation brackets
383 malibu
24
Anna, Ohio
Does any body have any issues with the tires rubbing the relocation brackets? It seems like they would be really close if you had some wide slicks or notched the frame. What hole do you use I see that some brackets can be up to 4 inches lower. Is any body using the bottom hole. I am trying to get my suspension set up this winter.
Thanks for the help
Supe
15,116
Charlotte, NC
The only way I could see you having a problem is on something smaller than a 15" wheel.
dasbrdr
411
Seattle, Wa
Ya I had this problem. The brackets rubbed the lip of my wheels. Although my car is frame notched with 10" wheels. It was a simple fix to just cut the bottom corners off at a 45 deg angle with my hacksaw. Took about 5 min for both sides.
