The TV/ThrottleValve Plunger in the Valvebody may be sticking/binding, a very common problem in older trans with some miles on it. This can cause all sorts of wierd shifting problems, especially when the Trans gets hot.
TV location>> http://www.sonnax.com/system/announcement/65754-01K.pdf
Many don't realize the TV Cable isn't like a Detent/Passing gear Cable used on a TH350. The TV Cable controls line pressure, shift points, shift feel, part throttle downshifts and the detent downshifts."
The TV Cable's adjustment and Bracketry is critical to 2004R, 700R4/4L60 Tran's life & operation.
Are you using the required TV geometry Corrector Bracket?
Eddy>> http://www.summitracing.com/parts/SUM-700203/
Holley/Demon>> http://www.summitracing.com/parts/SUM-700202/
A good quality, rigid TV cable Bracket is also required.
