rim question on a 9"
Excelerater
6,798
Memphis,TN
im running a 68-72 12 bolt drum brakes w 15x10x6.5 w frame notch
I am planning this week to order up a 9" w stock Gbody lenth and disc brakes so do I now need a 15x10 w 5" or 5.5" BS ?
anyone have a 9" w frame notch? what rim did u run?
BottleBaby Bu
859
Houston, Texas
www.Houstonhotrods.net
Im running a 15x10 with a 5" bs. 29.5x10.5 sits right in the wheelwell where you can lower it over the tire without rubbing.
4doorbu
1,877
south jersey
i have a moser 9" cut 7/16" each side with a 10" rim 4.5" bs with a 28x10.5w tire. soo around 5" is what you'd want. i have 10" with 5" bs with 325/50 radials and had to use a 1/2" spacer with my rear narrower.
