79 El Camino 12 bolt swap rim and tire Questions
ratengine
195
Chicago, IL
I have a spare 12 bolt off of a 71 Chevelle. I have the rear upper and lower control arms swap kit it's offset for the angle difference. I will move spring perches up top. Shock mounts not a problem.
My questions, rims and tires for the rear. I know the 12 bolt is little wider. I Plan on running the Torque thrust II, rim size 15 X 8 and rim backspace 4.5" inches.
Rear Tires I'd like to run size is a P275R15 . Has any one run a 12 bolt with this size tire and rim combo without any issues? Lips have to be rolled? Chassis clears?
For those who have installed a 12 in a 78- 87 G body what size rim and tire worked for you?
What's the best size rim and tire for the 79 El camino with a 12 bolt rearend, for a street car no track time!
Thanks Dave
ratengine
195
Chicago, IL
Well it's done. Note: Rim Sizes for the rear swaps are 15 X 8" with either 3.5'"or 4.5" back space. Some myth busters to not worry about to install a 12 bolt in a 79 Elcamino. Don't have to change spring mounts to top of the rear axle. You have to shorten the drive shaft. Best to get the offset upper control arms, they have some nice USA made ones sold on Ebay. 3.5" rear back space rims are the best fit with a 8.5 or the 7.5 rears. With a 12 bolt 4.5 B/S with a P275/60/R15 will clear lip on rear quarter, and not rub against rear inner frame rail. The 68 thru 72 Chevy 12 bolt is 1/2 wider on each side. If you run a 4.5"B/S with a P275/60/R15 on either the 7.5 or 8.5 rears you will rub the on the rear frame rails and need 1/4" wheel spacers ,1/2" will give more clearance to clear rear frame rails. With the Chevy 12 bolt install no spacers needed with a 4.5 B/S rim. I just finished installing a 8.5 and 12 bolt in 2 elcaminos, And I have both 3.5" and 4.5" B/S rims. with 60 series tires. The 8.5 swap is a direct bolt in yes but you must cut the driveshaft on the elcaminos and a Grand national driveshaft of 55 1/2" is to short, so have yours cut and balanced for the elcaminos. Now for malibus and other G bodies your on your own your better off using a 8.5 or a 67 12 bolt, good luck finding one. When it's all said and done it's worth it. Hope this helps others doing the swap.
bowtie81
5,008
sarnia, ontario canada
I have a 67 12 bolt and using 15x8 rims 275 60's and 5.5 b/s, fits perfect on mine.
V Correct GM bell housing part number 1987 El Camino Drivetrain Technical 3
DOUG213XRJ Malibu El camino front air dam questions. General Discussion 5
DOUG213XRJ Daily broke down, So out came the El Camino General Discussion 5
7 5th gen El Camino tach issue Electrical/Wiring Technical 2
7 78 El Camino plastic chrome horn trim Interior Tech 2
B 1980 El Camino Carb to TBI EFI Tech 3
D G BODY EL CAMINO DRIVESHAFT? ????'S (700R4) TRANS Drivetrain Technical 5
G Malibu/El Camino Door Skins Autobody/Paint Technical 6
N Rear springs for 83 el camino Suspension Technical 0
9 Who has a dual exhaust kit for a 87 El-Camino Drivetrain Technical 0
V Vintage Air A/C for El Camino or G Body??? Interior Tech 2
flatblack79 El Camino Door panels in Malibu? Interior Tech 4
T how to make an el camino hook on a budget? Suspension Technical 2
A 1984 El Camino and 84 Malibu Electrical/Wiring Technical 2
Apathy93Z How far back for later Camino mirrors on 79 Malibu door? Autobody/Paint Technical 0
90Gabe El Camino 700r4 Jegster X-Member Transmission Technical 0
7 El Camino quarter window felt replacement Autobody/Paint Technical 1
M el camino 1/4 glass molding pic Autobody/Paint Technical 0
Bald Menace el camino interior parts? Interior Tech 0
81elcamaro 81 EL CAMINO LS1 LSx Tech 19
8 Tach stoped working on 84 El camino.. Any ideas? Electrical/Wiring Technical 1
abigda BBC El Camino wheel hop Suspension Technical 6
D El Camino EFI EFI Tech 4
B turbo el camino vid Power Adders 125
R 400 trans in 79 El Camino Drivetrain Technical 20
E El camino tow rating LSx Tech 11
A 73-77 el camino rear Drivetrain Technical 1
Darwinskeeper Fiberglass parts and the Daily Driven El Camino? Autobody/Paint Technical 1
A El Camino SS nose conversion Autobody/Paint Technical 7
M 275 60 on an El Camino. Wheels/Tires/Brakes Technical 1
elsky79 el camino wheel wells? Wheels/Tires/Brakes Technical 1
Blackwizard22 El camino same as mailbu in wheel bs? Wheels/Tires/Brakes Technical 3
N tire size for 85 El Camino Wheels/Tires/Brakes Technical 2
78Camino El Camino Rear slick size.... Wheels/Tires/Brakes Technical 3
7 Where does the radio bolt in the dashboard? Interior Tech 13
T Bolt out front crossmember Suspension Technical 7
A Gm 10 bolt 8.5 carrier bearing preload Drivetrain Technical 3
D 1984 B-Body wagon... 12-bolt cover??? Drivetrain Technical 1
JRL1986 What is the real answer for a 12 bolt swap??? Drivetrain Technical 5
D Cost to build thoughts... 12/10 bolt swap, 8.8/9" swap Drivetrain Technical 4
78_Landau How much is too much to pay 442 10 bolt? Drivetrain Technical 15
A 12 bolt cross over Drivetrain Technical 3
V 8.5(10 bolt) to 12 bolt? Drivetrain Technical 2
T 8.5 10 bolt posi Suspension FAQ 1
U UMI Releases New Product-G-Body Bolt In Relocation Brackets Suspension Technical 5
H Backspacing on 78 81 malibu g body with a body 12 bolt Wheels/Tires/Brakes Technical 1
T 12 or 10 bolt IC swap kit into a G body Suspension Technical 3
Z replace bent tube on 10 bolt rear -end Drivetrain Technical 8
M Seatbelt bolt question Interior Tech 3
D Early vs late model sbc - pressure plate bolt pattern Transmission Technical 6
Similar threads
