rocker replacement pics?
tahoemike96
67
Selkirk, Manitoba. Canada
rockers on my 81 malibu are rotten so i picked up a set of replacement ones. looked a little closer and the inners are gon to ](*,) does anyone have any pics or info on what they used to relace all this mess. any info would be great.
melloelky
3,654
31
mass
hey mike,as far as the inner rockers go you can just replace it with a sraight peice of steel.to get the old one off you need to drill out the spot welds out and seperate it from the floor.whats nice about this is you can rust proof the inner and outer @your convience like making small holes that you can plug with plastic plugs when done spraying a rust fighter of sorts in there.be sure to seam seal everything when your done welding. good luck any ?'s just ask!
