Round gauge idiot lights to gauges swap
Chevys_Only
Member
Nov 22, 2012
8
Altoona, PA
I recently purchased an '84 Monte Carlo that was equipped with the round speedometer type dash, but it has the idiot lights in place of the oil pressure, temp and volt gauges. This isn't my first G-body so I had an extra cluster that had the gauges I wanted in my dash. I didn't see any posts here about this swap, so maybe this will help someone out. I was hoping to just disassemble my cluster and swap in the gauges in place of the idiot lights but no such luck. The back half of the cluster housing is not made to accept the gauges, it will only accept the idiot lights. It also requires a different printed circuit. It isn't a deal breaker for me as I have a complete cluster for parts, but the spare cluster was blue, mine is brown, so now I have to dye the housing to use it in my dash instead of reusing my original cluster housing. It appears the wiring will not require any changes, but I am going to remove the brown wire (Pin 1) that went to the alternator and connect it to ignition power thru a resistor as shown in the wiring diagram, this will insure the alternator charges properly.
Chevys_Only
Member
Nov 22, 2012
8
Altoona, PA
An update on what is necessary for the swap. When I got to the original oil pressure sensor, the connector has four wires on it. It is a multi-function sensor, it controls the choke heater on the carburetor as well as controlling the low oil light in the dash. I am going to have to use two sensors to keep everything working properly. I will add the additional gauge sensor along with the original sensor. It's necessary to remove the tan wire from the original sensor connector and attach it to the gauge sensor. The other wiring on the original sensor can remain the same. The coolant temperature sensor only requires removing the original switch type sensor and replacing it with the gauge sensor. The wire that originally controlled the light will now be the sensor wire for the gauge, it is dark green in color.
Chevys_Only
Member
Nov 22, 2012
8
Altoona, PA
Swap is complete, everything is working properly, I did make one change from my original plan. The dash warning light panel has a "Choke" indicator light that isn't used on this car. By removing the dark brown wire from pin 1 of the dash connector and placing it in pin 14, which was empty, the "Choke" indicator now works as my charging indicator. If that light comes on I know the alternator isn't charging.
Killerdave8813
885
Cincinnati,Ohio
Sounds good! I was thinking about using the choke light on my 78 as a "check engine" light for the Tuned Port Injection but haven't got that far yet!
Tony_SS Sweep/Idiot Light to Round Gauge Conversion Electrical/Wiring Technical 2
Macrisel Round gauge swap wiring question Electrical/Wiring Technical 1
K Round basic gauge to round w/tach question Electrical/Wiring Technical 13
G Straight Line to Round Speedo Gauge Cluster Electrical/Wiring Technical 2
D Round gauges printed circuit board... replacements? Electrical/Wiring Technical 2
A Cylinder taper/out of round Advanced Technical 15
A Gas Gauge is off Electrical/Wiring Technical 3
R Gauge panel General Discussion 2
V Pulled Gauge Cluster ( no power to accessories) Electrical/Wiring Technical 0
82wagon Sweep style gauge bezel. Interior Tech 8
Macrisel Gauge confusion Interior Tech 21
3 Gauge and Dash Delima Interior Tech 8
R gauge plate in father/son build Interior Tech 5
O Auto meter fuel gauge question Electrical/Wiring Technical 2
7 Gauge Box Interior Tech 8
elcaminoss84 gauge cluster help Interior Tech 1
80malibu-604 Rally gauge question Interior Tech 2
81Malibu-4DR 1979 Regal custom gauge cluster? Interior Tech 0
JUAN W egt gauge Alcohol/Ethanol 1
F 1981 malibu gas gauge Electrical/Wiring Technical 23
bcubed Gauge Cluster Idiot Lights Interior Tech 4
B FUEL GAUGE WIRING Electrical/Wiring Technical 3
M Gauge Angle Rings Interior Tech 0
7 temperature gauge and oil pressure Electrical/Wiring Technical 9
K Gauge Cluster F'd (time to rebuild) Electrical/Wiring Technical 3
S Trouble with oil pressure gauge Electrical/Wiring Technical 3
8 Gauge Question LSx Tech 12
79ChevyBu Gauge Lense Interior Tech 8
T Help with Gas gauge Electrical/Wiring Technical 1
D Gauge Pics Electrical/Wiring Technical 63
SLICK78 Another Rally Gauge problem Electrical/Wiring Technical 9
RobMalibu79 Fuel gauge issues Electrical/Wiring Technical 5
K Gauge panel Electrical/Wiring Technical 3
S Gauge Lights to Sweep Gauge swap?? Electrical/Wiring Technical 6
C Autometer fuel level gauge Electrical/Wiring Technical 6
N Gauge Installation Electrical/Wiring Technical 2
MalibuRacing Dash and Gauge Cluster update MalibuRacing Father/Son Project 16
tumtum cant get my new VDO electric water temp gauge to work!!! Electrical/Wiring Technical 5
A GAUGE CLUSTER Electrical/Wiring Technical 4
A Autometer Phantom Gauge, Lokar Speedometer Cable Electrical/Wiring Technical 1
E Autometer electrical trans temp gauge Electrical/Wiring Technical 3
STROKER_STEVE oil pressure gauge monte ss Electrical/Wiring Technical 2
starfire350 Innovate LC1 Wideband w DB Gauge Kit LC-1 EFI Tech 0
B temp gauge Transmission Technical 2
80Grand_LeMans Gas Gauge Electrical/Wiring Technical 10
406Monte Covan Classic Gauge Cluster for all G-Bodies coming soon Electrical/Wiring Technical 15
C fuel level gauge Electrical/Wiring Technical 1
C auto meter gauge installation Electrical/Wiring Technical 1
MalibuRacing Parts cleaning, Sensor adapters, gauge cluster - 11-28-08 MalibuRacing Father/Son Project 21
406Monte Possible bad volt gauge Electrical/Wiring Technical 5
Similar threads
