SBC 350 & Thumpr Cam ?
gbodyera
190
Miami- Detroit
Could a Comp Cams Thumpr Cam(PN 12-600-4) with .479/.465 lift run in a stock SBC 350(1.94/1.50 valves) 76cc chambers with 2:56 gears and 350 trans?
Night Stalker
1,125
Genoa,Oh
shadychevyowner said:
not with stock heads way to much lift
Yeah right,,,,,,,,,,,,,stock GM heads and springs will go to a .500 lift on a hydralic camshafts easily..
lurchsmalibu
3,774
Lakeland, Florida
The 80's called and want their 2.56 rear gearing back! ;) J/K... 8) Any stall TC? It should be compatible, but will be a dog at first. You may not get the RPM's that you want because of the stock valve train. :-k
Night Stalker
1,125
Genoa,Oh
lurch,, the stock valve train won't be the problem,,it'll be the smaller intake runners.. ;) ;)
gbodyera
190
Miami- Detroit
I thought stock spring could handle maybe .470 or .480. idk Whatever the case. Comp Cams says it will run fine with a stock converter but will be better with at least a 2000 stall. My only concern is the springs.
Night Stalker
1,125
Genoa,Oh
A stock spring will handle up to a .500 lift hydralic camshaft with no worry of coil bind.. I'd look at a little B&M or TCI saturday nite special converter in the range of 2000-2500.....
gbodyera
190
Miami- Detroit
Cool. Thanx for the heads up if you will. Do you have any vids with it idling?
