SBC Engine Setback
tiedyemike8
658
Naperville, IL
Are there any drag or street race guys on here that have set the engine back in their G-body? Does anyone know how far a small block can be set back without firewall modification?
I haven't done this before, I'd like to move the motor back 4-6", which i figure will require the firewall to be moved. Also, should the crank centerline be adjusted?
Does anyone have input on this?
tiedyemike8
658
Naperville, IL
Any input guys?
bowtie81
5,008
sarnia, ontario canada
I know a guy who moved it back and inch or so, didn't have any problems. Why do you need to move it back so much?
tiedyemike8
658
Naperville, IL
I know it will help with traction, weight transfer by improving weight distribution and the car's center of gravity. I'm sure it's not necessary for me to do it, but I think it would be beneficial, and the car is already apart. Working on narrowing the rear frame rails right now. I figured if I'm going to do it, now is the time. It would be easiest to mock it up and modify the firewall now, while its apart. I don't know if 1-2" would be worth the effort, but maybe 4-6" would.
