MISFITmalibu63 said:
so, since my car is a street car, im gonna run a mechanical pump to feed the engine. as for the nitrous, i want to install a small 3 gal fuel cell to run 110 in and feed the nitrous plate. right now i have it jetted for 125. what electric pump can i use, and also what pressure should it be set at??
I dont like a blue pump for this application......
reason one it has no bypass and will creap like a **** (pressure buildup)mounted up front
two it is not very repeatable,turn it on once then turn it on again and the pressure will vary
often people forget to turn on the front pump ,I recommend your arm switch be also your pump switch.
Id rather see a nice pump like a Mallory 140 to power the entire car from the rear and feed into a dist block mounted
somewhere in the engine compartment...140s are quiet and plenty large some a combo like yours
hobb switch .....never.......
very erratic and usually cause more trouble than good......
