Shock advice
willny1
Member
Apr 24, 2008
6
I am looking for some suggestions as to which shock I should go with. I already have the Moog #5658 spring for the front and will be getting Moog # 5413 for the rear. I heard the Bilsteins are top choice but can be pricey.
I would like to compare the Bilsteins to the Monroe and KYB shocks. I dont know what part number I should be looking for. I was told that the shocks should compliment the springs...
Any suggestions for the springs I have? Part number etc...Will be ordering though Summit.
I would like the car to handle well rather than just being a straight liner.
It has a GM 350.
86 regal.
My set-up really isn't the same, as I have REAL stiff springs and a real low ride height. But I had KYB's, and went to bilstiens and the difference was nite and day. If you can afford them, bilstiens all the way. If it is lowered some, get the s-10 extreme fronts, and call bilstien to get shortened ones for the rear.
And the shocks SHOULD complement the springs. As the spring rate rises, so does the need for a shock with better valving. If you use a soft stock shock, with a mild compression/rebound valving, and a stiffer spring, it won't be able control the stiffer spring rates through the up/down of the suspension travel. IOW, it will be bouncy. That is what happened to me.
Norm Peterson
251
state of confusion
If you haven't bought shocks already . . .
liquid's advice is good. While KYB (I'm assuming Gas-A-Justs here) can handle those springs, the Bilsteins will do so at least as well, while giving you a better ride. GR-2's are OE-replacement or maybe half a step better, and not really up to the job.
If handling has any priority at all, or if your car is lowered, or if both apply - lose the name "Sensatrak" from your vocabulary. The big design feature in those shocks that's responsible for the ride comfort claims ("position-sensitive") is pretty much opposite to what you want for a car that is happy about being driven hard through the turns.
Norm
rjleiker
261
Derby, KS
As far as shocks are concerned, should I be looking for a specific part number like springs? Or do I just need a certain type or brand that is specific for the vehicle?
Norm Peterson
251
state of confusion
Normally, all you need is the shock make (and perhaps model) and your car year/make/model. But if you've got significantly stiffer front springs (as in over 600 lb/in) on these G-bodies, I think the front shocks from some years of 2WD S10 may work a little better.
Norm
I'm fond of the Edelbrock IAS shocks. IMO much better than the KYB & Bilstein "expense-a-tracks", but then again, shocks are somewhat subjective. What one person loves, another hates... AFAIC, Norm is THE suspension guru.
Supe
15,116
Charlotte, NC
X2 on the IAS.
I agree with norm. I have 900lb/in fronts, and 275 lb/inch rears in my chevy wagon. I used the KYb's and they counld't dampen the spring. I used Bilstiens front/rear and am very happy with the ride. Albiet FIRM :twisted: But my wagon is a tank.
