Small block Chevy 400 engine with different pistons in it ??
dickeymoore
818
Atlanta,Ga.
A friend of mine has a small block Chevy 400 stand bore engine that runs ran good and we decided to change the heads and cam in it after removing the heads we realized that six of the Pistons are aftermarket dished pistons and two of the Pistons are Factory dished Pistons can this engine continue to run like this or what will the problem be? THANKS
TURNA
6,028
Socialist NY
Re: Small block Chevy 400 engine with different pistons in i
If it ran .....it should continue to do so.
lilbowtie
1,736
Canton Mi.
ditto Turna they are probably factory replacements and hopefully the weights are the same or balanced to each other.
