what HP level are you at? I was figuring high enough to stress the block.455_82malibu said:what does block material have to do with anything, its lighter and at my power levels just as strong. i know ill be down HP, but i can always add more boost to even things out...i hopekyhunter89 said:no offense... but i feel you took a step backwards... not only from a 6.0 to a 5.3. but also from an iron block to aluminum... seeing as yur running FI
um, lq4's are 600-1k around here. lm7's run about 5-600 on average. not worth it there, seeing as the 6.0's have stronger rods and would survive longer and the same hp level on less boost, and boring to a 5.7 and getting new pistons isn't going to be cheap comparing to picking up a stock 6.079loserbluebu said:All of the 5.3's come aluminum now, and for the price people are paying for a solid 6.0 shortblock. Which, you can always get worked to a 5.7 safely on the 5.3 block.
kyhunter89 said:um, lq4's are 600-1k around here. lm7's run about 5-600 on average. not worth it there, seeing as the 6.0's have stronger rods and would survive longer and the same hp level on less boost, and boring to a 5.7 and getting new pistons isn't going to be cheap comparing to picking up a stock 6.079loserbluebu said:All of the 5.3's come aluminum now, and for the price people are paying for a solid 6.0 shortblock. Which, you can always get worked to a 5.7 safely on the 5.3 block.
kyhunter89um said:Right, I never said he had to do anything to the 5.3 block. He can go up to a 5.7 bore if he ever wanted to. But it's much easier to find a 5.3 than a 6.0.
79loserbluebu said:kyhunter89um said:Right, I never said he had to do anything to the 5.3 block. He can go up to a 5.7 bore if he ever wanted to. But it's much easier to find a 5.3 than a 6.0.
5.3's are about half the cost as well.
That sucks. Around here a 6.0 is like a 400 sbc and a 5.3 might as well be a 305 lol. I've seen complete 5.3 with decent milage go for around 400 bucks.kyhunter89 said:not on my area...LT1_Malibu said:5.3's are about half the cost as well.
