well heres the scoop. my starter Powermaster mini starter. i accidently cross threaded the ignition bolt on the starter. so when i would tighten the bolt the entire screw would turn with the nut. well this broke an inside wire from the Screw so i soddered it back together, but now its got a weak signal.. it kinda has a hesitation when i try to crank it, and a lil clicking noise. I used regular solder ... should i let it go for now or do u think it'll break and not work? or should i yank her and take it to a starter place and have it reworked???
