Steering colum wiring
Wile E
1,075
Central WISC
I found a tilt colum out of a manual El Camino, I know it will bolt up. Just not sure about the wiring harness, My 'bu was an auto. Any troubles with this swap?
Toner283
293
Arthur, Ontario, Canada
The wiring should clip together no issues. If your car is an auto I would sell the stick column & get an auto tilt column & pocket the difference. Factory tilt columns for manual g bodies are rare & worth $$$ to guys who are looking for them. You should be able to buy a tilt column for an auto for $50-100 depending on whether it has a multi switch or not and whether it is column shift or not. The tilt column from a manual car should get you $150-250 depending on condition (and if it is a factory piece). Might even get more on fleabay. Just an idea. I would like to find one myself but sadly no spare $$ right now.
Wile E
1,075
Central WISC
Yeah, I picked it up knowing they are rare, paid 25.00 at the salvage yard. Looks like 3 of the connecters match my original colum. The manual colum has 1 other wiring socket that mine does not have, not sure what it is for. The colum is in remarkable condition. Just don't want a melt down cause I made a simple mistake.
Sounds like the deal I got. Neither of mine have the key-lock thing (keeps the cylinder from turning all the way back & locking the column when you turn the ignition off), but I have a tilt, and a non-tilt column (non-tilt was after my original column was broken :x), but I scored the tilt column for $20. The column shop I bought it from is slightly old school (one of the guys builds rat rods for a hobby, he's the one that sold me the column), the owner said he could replace the column-shift collar with a floor-shift one.
winditup57
848
Davenport, IA
I just picked up a black floor shift tilt column at a swap meet for $75. It is in great condition, but it is out of a newer car with cruise and delay wipers. Hopefully I can make it work with my 80
Wile E
1,075
Central WISC
My mistake, the extra socket/wiring is on my old auto colum, not the manual one. Here's the pic. Whats that socket for?
Here's the manual colum I will be using,
Toner283
293
And the park/neutral start switch. Standard cars have a clutch switch instead of a neutral start switch and the reverse light switch is in the trans.
Wile E
1,075
Central WISC
Thanks for the info
