swap and carb vs. efi questions
SSR 5.3 = Aluminum if I remember right. The car craft article I read used an 'SSR' 5.3 engine, and they said it was aluminum. I'll look for it later tonight after I get home.
HarrisonTX
3,332
Burleson TX
Horsepwraddict said:
T5MalibuWagon said:
another question, do 5.3's have aluminum blocks?
no. The 4.8 and 5.3 share the same block
an LM7 is an aluminum 5.3, so does LH6
Horsepwraddict
1,581
Princeton MA
i stand corrected. An aluminum 5.3 would be damn fun in my truck, on top of all the weight reduction ive done it probably weighs less than the 4.3 that came out of it.
For what its worth, the ls1 blocks aren't that strong. The iron blocks can handle upwards of 900hp from the factory. But for any mild build, i would love the weight of the aluminum block.
T5MalibuWagon
1,386
Fort Worthless TEXAS!
Thanks for all the replys.
Drwoo, Whats that in, and what engine did you go with? Looks bad a$$ with that black carb :twisted:
All the swap pics I have looked at retain the power steering pump, in my swap I wouldnt need anything other than the alternator. Is there a way to only run the alternator or do I need to find a power steering set up for my car so I dont have a PS pump just hanging out.
455_82malibu
1,400
WISCONSIN
yes, just dont run the pump, you can trim the alt-powersteering bracket down. keep the tensioner and get a shorter belt. My brother just runs the alt, waterpump, crank and tensioner, no idler and has no problems with the belt even at 7000-7500 rpm.
T5MalibuWagon
1,386
Thaks for the info. I dont really want power anything, just more stuff to go wrong and more weight.
HarrisonTX
3,332
Burleson TX
Thats what im talkin about!
T5MalibuWagon
1,386
Ya I know your finally rubbing off on me, lol. Man the difference in working on your bu and mine is killer. I think I would rather pull a head on yours than a valve cover on mine. With this car not having any power it just makes sense to me ;)
