Hmmm, seeing how you have a 6.0 the factory flexplate should be okay to bolt up the transmission with a sbc style converter. The Lsx engines need a spacer on the crank to work with an older style transmission. Jegs sells the spacer and the bolts for around $75 total but you may not need it depending on which flex plate you have.
