th350 to ls 6.0
bluebu79
Member
Jan 6, 2012
7
what do i have to do in order to bolt my 350 to the ls 6.0 any special part i need please let me know
LT1_Malibu
202
Greenup, Kentucky
Hmmm, seeing how you have a 6.0 the factory flexplate should be okay to bolt up the transmission with a sbc style converter. The Lsx engines need a spacer on the crank to work with an older style transmission. Jegs sells the spacer and the bolts for around $75 total but you may not need it depending on which flex plate you have.
LT1_Malibu
202
Greenup, Kentucky
Here's a really helpful thread. There's a link posted from me about 5-6 posts down to a LS1tech.com thread that has 100% everything you need to know.
http://www.maliburacing.com/forum/viewtopic.php?f=29&t=59635
455_82malibu
1,400
WISCONSIN
usually if the truck was a HD or had the 4l80 trand it will have the spacer....if you get a large bolt converter the holes are already on the flexplate, if not you have to grind a little for the smaller th350 circle
bluebu79
Member
Jan 6, 2012
7
i looked today at the flex plate i did see the spacer on it it went crank, spacer, then flex plate is that right
