I just had my th350 rebuilt, and now it has no second gear....
What could it be???
Everything else works, But second ](*,)
What could it be???
SSedan64 said:If it makes a 1st to 3rd & 3-1 shift the Intermediate roller clutch may be in backwards or damaged.
It would have all shifts manually tho', with stock Vbody.
Bar50 said:Make extra sure the shifter is adjusted and not traveling over too far or too short.
"Intermediate roller clutch may be in backwards or damaged" in a 400TH you can put them on backwards, or if you have the 34 element sprag like a 400TH.
Did it function okay before the manual valve body?
Does it have reverse?
I did one the other day, loosing pressure the stator in the front pump had a fracture in it, under the bearing on the back side of the pump. Everything else had checked out, it just air check funny for no reason. That's where my pressure loss and variation came from.
I am interested in his process for:
"O I forgot to add that He made it fully manual..."
Like plug the governor passage, lock out the throttle pressure valve, lock up the manual low valve...?
