Originally posted by littlefranks:
[QB] PUT A SET OF ARP ROD BOLTS AND HEAD BOLTS IN,243 casting heads,ls2 intake 90mm tb ,cam 54-449-11 comp cam, valve lift 605 int 609 exh lobe sep 112.0 adv dur 287/289 th350 with 3500 stall 373 rear 3700 pounds garateed to go bottom 10s every time with a 150 hit.7.40 on motor 6.50 on the hit in the 1/8 .
60 ft 1.393
330 4.132
1/8 6.463
MPH 104.81
1/4 10.220
MPH 129.93
http://www.ls1tech.com/forums/generation-iii-internal-engine/694469-thoughts-asa-gm-hot-cam.htmlDoober said:Sounds good!
Do you have a link to the specific thread? I'm down for some readin'.
