Tire Size
Hello, I Need A Little Help Here i See People Talking About Using A 295-50-15 Tire On A 8 Inch Rim, But I Need To Know Will They Fit On Bu With No Frame Notch? And With A 3.5 BS With Stock REar? Thanks For Any info.
JRodS79
1,567
kansas city mo
i know that alot of people get away with doing different stuff to fit large tires under the car.
i just bought some 275 mt streets to get by since my rear end is off about a 1/2 or the car is who knows!!
first thing is your going to want to measure from your frame to the axle and make sure the car is straight and to make sure the rear end is equal side to side. even if everything is stock, factory stuff on these cars are known for being off a little
what tire are you thinking of because they dont make a 295-50-15 in an et radial
the 295-65-15 is a 30x12.5x15 so it will need a 9-12 in wide wheel to be right the biggest tire iv seen stock body is a 29x9 et drag so i would say it will need mini tubs and frame notch to accomodate <- sp the extra 1.5-2 in wider the 295s will be
ok
Ok Basically Im Just Trying To Figure Out What The Biggest Tire Size Is That I Can Run On A All Stock Rear End, With 15-8 And 3.5 BS Any Help Would Be Appreciated.
Doug Keen
2,259
Central, Illinois
Re: ok
28x10.50 ET Drag will fit, may need to roll quarter lip or light frame notch.
Re: ok
Awsome Thanks Whats The Biggest Radial Tire That Will Fit? With No Frame Notch? Thanks
lurchsmalibu
3,774
Lakeland, Florida
295's is kind of too wide for an 8" rim isn't it? I have 275's on 8" and the sidewalls are tapered quite a bit.
This has a few pictures that might help. http://maliburacing.com/forum/viewtopic.php?p=337318&highlight=#337318
RamAir468
196
Albany, New York
I'm running a BFG drag Radial 275/60R15 with rolled fender lips and no notched frame, on a 15x8 rim with a stock rearend. I could probaly squeeze a bit more tire in there. :D
cool
KK Cool Thanks Alot Guess Thats What I Will Try Then.
That With A 3.5 BS?
JRodS79
1,567
kansas city mo
ya 3.5 will work with that
iv also seen 29x9x15 stock body and frame
