trans sending unit
Z-man
1,058
Barnesville MN/ Fargo ND
Redcutlass said:
If it looks like an oil pressure sender and has 2 prongs on it, it's a polution control device that was used to retard the timing back in the old days.
X2
makurtz
Not a good place for temp sender. There is only oil there in 3rd gear anyway. Put it in the oil pan.
cartoyz4me
15
broken arrow,ok.
if it is leaking like they all do,you can just pull it out and put a pipe plug of the same size in it,it is to retard the timing at highway speeds,at every transmission shop i have worked at thats what they did,hope this helps
