transmision check ball locations?
83bu
563
Regina, Saskatchewan
i need help on where the check balls go in a th250c. anyone have a diagram?
DFWMalibu
999
Dallas,Tx
you should be able to use vaseline and stick the balls up in the transmission case... it's obvious in the case where the balls go and the vaseline will hold the balls in place while you install the valvebody...
Chris K.
83bu
563
yea i can kind of see where they go but i only have 4 balls and im not sure if that is the right amount because it looks like there could be 5 spots. thanks for your help.
DFWMalibu
999
Dallas,Tx
yeah I am not positive on a 250 I know that's how to do it on a 350 sorry I couldn't be more help...
Chris K.
83bu
563
rented a book from the library and got it figured out. thanks for the help tho.
Similar threads
