Trick spring help!!!
dray1979elcamino
89
Moroso Claim that they don't have a front spring for my El camino. I took it to the scales and the front weighs 2020 lbs. This is with steel hood and cast iron heads. Plans include 4 inch fiberglass hood and set of aluminum heads. Should bring the weight to around mid 1900 lbs. Tech said the closes spring he has is the 47135 which is the 250 lb spring rate and 1800-1825 front end weight. i have trouble understanding this. and was wondering if anyone has a comparable front end weight using a moroso trick spring and how are your results
TRZ Motorsports
362
Orlando, FL
www.trzmotorsports.com
Another option is a Malibu Moog V6 spring.
