turbo 350
prairiehotrodder
1,576
Melfort Saskatchewan Canada
do you mean extra clutches? They are in trannies that have been rebuilt and machined to accept them.
brian
prairiehotrodder
1,576
a big truck would not have a turbo 350. Turbo 350 was not used in heavy duty applications. I have seen them in 3/4 tons behind a 350 or a 400 small block but nothing more HD than that.
brian
SSedan64
948
MACON, GA.
Increasing TH350 clutch count.
Info here >>
desbird
347
whitehall michigan
trucks in 69 20 seris on one car part site had a power glide listed the trans in got for parts was suppose to be out of a dump truck 69 long tail shaft WHERE DO I FIND CODE this trans is a 350
art
249
Mastic, New York 11950
SSedan64
948
MACON, GA.
TH 350 ID Codes:
69-72 Buick = Model & Calibration stamped on 1-2 Accumlator cover.
73-81 Buick / Chevy = Model stamped on Governor cover and Calibration stamped on right side verticle surface of Pan. Chevy Pan code only indicates Plant, Year, Month, Day of Month & Shift.
About 80-81 the TH350C got the Calibration Ink stamped or Stickered on the Bellhousing. Easliy removed when cleaning.
Vin # = Chevy, stamped on right side of Case just above Pan rail towards front.
Vin # Buick, stamped on left side of Case near Manual shaft.
If you get a Trans that's been rebuilt, the Gov, Acc. & Pan cover could have easily been changed.
