The turn signal indicators on my '80 Malibu don't work most of the time. Where do I start looking for the problem? The turn signals work fine but the indicators just don't show up on the dash.
#-o #-o #-ot5montecarlo said:168 is a higher wattage (brighter) than 194; you had it backwards.
388bu said:Do your actual turn signals work 100% of the time? Or is it only the indicators giving you problems? If not, it might be in the switch behind the steering wheel.
Not too hard to check assuming you have a puller.
