tv cable
malibumontana
Member
Mar 20, 2013
5
Lakeville, MN
i'm sure its been discussed here before but i have a universal tv cable and having trouble getting it adjusted perfect. i have heard that as long as you're at w.o.t. and the tv cable is wide open that everything should be good but it still doesn't feel right. anyone had this problem?
SSedan64
948
MACON, GA.
Do you have the TV cable Geometry Corrector Bracket?
It's needed when using an Aftermarket Carb, they don't have the proper Linkage for a TV cable. Without it, the initial TV pressure will be low at light to mid throttle & possibly low at WOT with an Eddy Carb.
For Eddy Carb >> Summit Racing® Throttle Valve Correctors SUM-700203
Instructions >> http://static.summitracing.com/global/images/instructions/tci-376710.pdf
Also make sure your TV Cable Bracket is strong & doesn't flex.
TV/ThottleValve Info:
TV 101, 3-Parts >> Bowtie Overdrives | TV Made EZ
TV Cable Setting & Pressure Info:
Pressure Gauge:
Pr. Gauge Only >> Amazon.com: Advanced Tool Design Model ATD-5550 Automatic Transmission and Engine Oil Pressure Gauge Kit: Automotive
Pr./Temp./Filter Combo >> Bowtie Overdrives - View Item
Pr. Gauge Install >> Bowtie Overdrives | TV Made EZ
