Unintended consequences
cutlass389
684
NC
I've been striving to improve the suspension travel in my Cutlass. I've increased the front up travel by 2.5" and the rear down travel by 1" along with new Hoosier 275-60x15 drag radials. Although my 60's haven't really changed, I believe that they will be more consistant and better able to handle a greasy or marginally prepped track. I'm getting daylight under the left front now and therein comes the new problem. I've got a new stumble on the launch that wasn't there before. I think the rear jets are being uncovered for a split second so now I've got to get some extensions for them. Discovered this today at test n tune. I made seven runs and the 60's were(in order) 1.612, 1.604, 1.606, 1.600, 1.601, 1.614, and 1.605.
Toner283
293
Arthur, Ontario, Canada
Did you try raising the rear float level a bit? A little more fuel in the bowl during launch might help.
cutlass389
684
NC
Good thought. No I didn't try that. It's set at 1/2 way through the sight glass so I thought that was pretty high already. 1st race is next week so I'll put extensions on just in case and I can raise the level if necessary. Thanks.
