I'd be interested in hearing what your definition of "cleaning up the ports" is like. I didn't have my 262 ported because I was afraid larger ports would hurt velocity/low rpm airflow. I just had a 3 angle valve job and drove on.
Here's a picture of what I intend to fix. GM explains this as a "manufacturing compromise"... i.e. cheap casting. The intake is OE cast aluminum, ports are matched nicely already. Not sure if I want a valve job, want to find out if it decreases valve life.
shifting up at about 3300rpm ... when you're mentioning a "4 speed" do you mean an overdrive automatic like a 700R4?
Well, I don't shift that late... no power that high up. Yours may do fine with that, but the 229 isn't a rever. Usually never see over 2500 rpm. This is on a stock '80 4 door sedan, original th200c and 2.41 axle. Rebuilt engine, carb, hei, all stock.
Yes, was thinking of a 2004r swap. But my car is all original, completly rust free. Hate to chop it up. Could just get a later model Monte with the 4 speed in it already.
I'm still intrigued by the mileage you're getting with your car. I remember reading that the EPA mileage for a '79 Malibu wagon with a 200 V6 and a 3 speed manual was supposed to be 22mpg City and 28mpg highway. That was all I needed to learn to be convinced that GM had found a way to game the EPA figures.
EPA estimates for my 229 sedan were 19/26 mpg. The EPA estimates were not done the same way as today, or even the mid '80s. Back then, remember the highway limit was 55 mph. That is where they got the highway estimate. If I do just city driving, and don't race the engine, can see 18/19. My usual commute is 70% at 70-75 mph, the other various city/country driving (start and stop), and I see 21/22 mpg. I've never seen 26 mpg, best ever was 23 mpg on a long trip going 75 mph. Maybe with some mild upgrades I could see better efficiency, but can't move the torque peak too high if you want good econ.
I've never experienced the 267/200 small blocks. With their long stroke, should have been good for low rpm torque and economy.
