vary mushy brakes
bbmonte396
200
Buffalo NY
this is for a 81 Monte Carlo
Ok I am having some brake trouble. When I press the peddle it is vary mushy then it is rock hard car will stop I installed all new brake lines, rear wheel cylinders, calipers, 2-master cylinders and 2 brake busters the only thing that is old is the prop valve but I cant see that being the problem because if it is mushy where is the fluid going? Now I have bled the lines with 2 large bottles of fluid. Might there still be air trapped in the lines? If not am I going crazy!
I guess I am willing to remove the prop valve with an adjustable one. If I do that the adjustable valve will go on the rear line and the front line will just run in to the master cylinder? And what adjustable valve would I be looking for I know they are rated in PSI
P.S I bench bled the new master cylinder prior to install 2 x
bowtie81
5,008
sarnia, ontario canada
what kind of wheel cylinders did you use? i had a similar problem and it was the new wheel cylinder was leaking, it was sucking air back into the system.
Kube.. for starters.. we cant help you if ya cant spell brotha!! what are boodles?
bbmonte396
200
Buffalo NY
i don't remember what wheel cylinders i put on. but i will change them out of you tell me what ones not to get lol
toxicbu
616
romeoville il
did you adjust the reardrums ? to loos and you will get a spunge brake,
bbmonte396
200
Buffalo NY
I will look at them a gen today but the peddle is all most going to the floor.
