What should I do
gstakes
15
My car has airbags in the rear should I keep them are go another way to help with the 60ft times.
bowtie81
5,008
sarnia, ontario canada
I see alot of people run air bags so they must help. I would keep them in.
MISFITmalibu63
7,163
The Sticks... Tewksbury MA
if you have trick springs, dont use the bags.
if you have stock springs with the same rate, put 1 bag in the pass side, try 15 lbs and see how it goes.
grizwald
3,300
Ontario, Canada
so you know, the rear end of your car will drop when you put trick springs in. i just did it and it lowered the back at least 1". just telling you in case that would cause an issue for you.
gstakes
15
I am tring to drop the rear about three inchs if I can the stock height is alittle to high for me
