wheel,s will they fit
lasttime78
465
An eight inch rim should have about 3.5 back spaceing. That works great to run 295x50xr15 in the rear. Not sure with taller rims. Good luck
boostinmalibu
756
joplin missouri
how wide is the 17" wheel? the lower profile tires on the bigger wheels, you can fit a wheel with more backspacing opposing a 15" wheel with a wider tire bulge
jrm81bu
413
Antwerp, Ohio
I ran 17x8 with 4.5 backspace with no problems. However 4" backspace in the rear would have looked better.
I have 17" x 8" on my car. The rears have 255/50s with 4.5" BS. The fronts have 245/45s with 5" BS because I have the B-body spindle/1LE brake conversion which widens the front track a little.
