Where do I hook up tach on TBI motor
malibulvr
1,929
Pensacola, Fl. 32526
My old daily driver 88 Suburban has a TBI 350 engine in it. I want to install an Autometer tach to keep track of the revs when towing. It doesn't have a regualr HEI dist in it. It has a small cap dist with seperate coil and brain box and I don't know where to hook up the feed to the tach at! If you know for sure please let me know. Thanks!
ScotSea
381
It has the separate coil? There should be a small two wire harness that runs from the coil to the distributor. Those are NOT the wires you need. There should be another connector to the coil, one a larger pink wire. If there is also a white wire there, that is the tach signal.
Scot
DOUG213XRJ
4,671
West, MI
I hook up a sunpro tach on my 1989 K1500 and the Green tach wire goes to the white or brown wire on the coil.
malibulvr
1,929
10-4, Thanks guys! I hooked up a tach on one of these years back and it fried the tach and I couldn't remember which wire I ended up using. Didn't want to do that again!
