let me change this which mounts can I use that won't mess with the fbody accessories and won't hit the a/c box on the firewall, I want to install the high mount a/c later
Ok let me re-ask heheh, which motor mounts have been used with f-body accessories and retaining the factory a/c box, i want to add high mount a/c later, and can I use the trans crossmember with some fabrication work or do I have to get a different one?
I used car shop S10 mounts on the motor, 2.8 mounts on the frame, but had to put a 3/8" plate between the mount and frame. The factory X member had to have the hole enlarged a little, but it pretty much bolted right in.
