Will a 15" x 8" 3,75"bs wheel fit under '79 Malibu front?
Alexander
318
Iceland/Norway
Rim Diameter: 15 in.
Rim Width: 8.00 in.
Backspacing: 3.750 in.
Offset: -19.00mm
Would this fit under my '79 Malibu front?
Cheers ;)
lurchsmalibu
3,774
Lakeland, Florida
Yes they should, I am running a steel rally 15X8 w/4" BS and only have rubbing issues with passenger(s) with 215/70/15 tires on the outer plastic fenderwell because I am running stock worn out 6 cylinder coil springs still.
malijusted
77
atlanta
I have Wheelvintique repro 15x8/3.75bs rallies on my 87ss and have never had any issues with them.
On a side not if you still have the original 78 spindles I would suggest swapping them out for some 79 or newer spindles. The wheel bearings are smaller and were prone to excessive wear.
