Wire identification?
DatBu
121
Northern IL
I have a couple rogue wires that I would like to cleanup. I don't recall ever having them hooked up.
First one is a large connector that sat to the left of the carb on the intake. Has a large red wire to the starter crimp and two dark green wires that are cut?
Second one comes out of the firewall next to the tach hole with a light green and blue wire to a female connector. Inside of the connector looks like a T.
Any ideas?
Thanks!!!
shvrolay
My guesses (from looking at a wiring diagram):
First one is to the AC harness.
Second 'sounds' like the back-up switch connector for a manual trans? (Wire colors are the same.)
DatBu
121
Northern IL
Car is originally non AC with stick. I have had a TH400 in there for 13 years, so this makes sense.
I appreciate you taking the time to look that up, thanks!
Matt
shvrolay
No problem......I think all cars had that connector in the harness - AC or not.
The other is definitely the backup light switch connector. If you could send me a pic of where the wires come out of the dash, I'd appreciate it. That way I can route my wires correctly for my manual trans conversion.
DatBu
121
Northern IL
Hi Tommy,
The wires come out of the harness attached to the steering column on the right. I can't open my driver side door to get better pics unfortunately.
Thanks for the quick response, I was actually looking to see where it comes out under the hood. Sorry for not being more specific.
DatBu
121
Northern IL
Hi Tommy,
There's a hole about 2" to the right of the tach hole on the firewall where it comes out. The hole is roughly the same size. If you need a pic, let me know.
Matt
DatBu said:
Hi Tommy,
Matt
A pic would be great, but it's no rush item...
