How To: Landau to standard B-Pillar conversion with pics
Moderator: Moderators
Bill in NC
Post by Bill in NC » Mon Oct 11, 2010 10:58 pm
OK guys I'm going to give this a shot, hopefully it will be helpful enough to get you started. Everyone does things different, this is how I did my conversion. It may take me a while to finish this :lol: , so bear with me.
I started out by getting all the parts I could think of before hand so I could do the swap quickly with no downtime. You will need to roundup;
-Standard windows - be sure to think about if you want factory tinted windows (A/C cars) or not.
-Inside upper and lower sail panels from a standard coupe - your b-pillar trim will work w/ both
-New window felts - you may need to trim the length slightly to fit your car exactly
-The black plastic trim that follows the roof/sail panel on the outside - standard is longer
-B-Pillar chrome trim - non Landau standard trim is thin and requires plastic clips to hold the trim to the b-pillar. Non Landau "Classic/Bright" trim is wide and wraps around the b-pillar post and attaches using the factory screws that hold the window roof seal retaining trim to the side of the b-pillar.
-3M windshield adhesive - I used one tube each side. A bit excessive, but there is no room for water to buildup and cause rust problems.
Here is the upper and lower sail panels removed. You can see the 2 nuts that secure the outer Landau trim to the car. Look very closely to the 2 lower sail panel attachment brackets. On the rear bracket you will see a pre-drilled hole less than 1/4" to the right and of the bracket (the other pre-drilled hole is behind the bracket in this picture). Looking at the foward lower bracket you will notice pre-drilled holes 2-3" foward of where the bracket is in its Landau sail panel position. During test fitting and final assembly, YOU WILL NEED TO MOVE THESE BRACKETS TO THE FOWARD PRE-DRILLED POSITIONS for the standard sail panels to fit CORRECTLY.
Remove the 4 brackets that help secure and set the window in the frame. 2 on the bottom, 1 on top, and 1 on the sail panel side.
Remove the Landau trim. Cut the factory adhesive. I used a utility knife with the long flexible blades. You can cut a window out quick w/ one of these.
Locate and save these isolators. You will need them for the new quarter windows to sit on.
Locate and remove and save the screws securing the Landau window felt.
Remove the outside black plastic trim from the roof line/sail panel.
Remove and clean all the factory adhesive.
On the outside find the seam where the standard pillar is seam sealed to the Landau pillar. I used the same utility knife to cut out the seam sealer to leave a nice deep straight groove to cut and seperate the 2 pillars. Some say you can seperate the spot welds from the inside, but cutting from the outside seemed really easy and quick.
At the bottom rear of the Landau piller you will find a welded/braised area securing the pillar to the quarter, a few seconds with a hacksaw blade takes care of this
The top was secured with several spot welds, so I just went straight across the Landau pillar only
I used an angle grinder with a cutting disk for the cut to seperate the 2 pillars. Make sure you do whatever necessary to protect your interior when you start cutting.
There are 3 or 4 spot welds in the inside. I sed a little grinder action and a few taps with the chisle
to get these loose
Ahhh, 1 more spot weld I had forgotten about....almost there
Boo-Yow! It's out
Clean up all those sharp edges and I recommend using your new glass as a template to straighten your window opening lip. GM did not care how warped the lip was while spot welding robots twisted the frames all up. The adhesive and window felts took up the slack so that you would probably never notice.
Use your new window to do as many test fits as necessary. The new window felt is in place in the photo. Also notice the "new" lower sail panel attachment bracket location in the foward pre-drilled holes. We reuse the rubber isolators that the window will rest on and window felt screws.
Now take it back apart and do any rust repair, body work, or painting needed.
I am missing several pictures of using the adhesive to set the windows, so I'll move on to some of the differences between all the standard and Landau parts.
Here we have the windows. The standard window is longer that the Landau window. You can also see why I told you to think about what windows you want to source (A/C or non-A/C)
The black plastic trim that runs down the roof rail and sail panel. The standard is longer than the Landau. These are the pieces that nobody tells you about needing :lol:
Here is a sideways picture of the standard b-pillar trim that needs the plastic reatining clips installed to use this trim. You will need to find a body shop that has a stud weld gun that can do the style you need for the clips or you can use short screws to attach the plastic clips to your b-pillar.
But I would highly recommend this route. The standard window Classic (Bright trimwork) b-pillar trim. It simply wraps around the entire outside b-pillar and uses the factory holes and screws that secure the window roof rail weather strip reatining trim. Takes like 30 seconds to install.
I hope this helps some of you guys out there. All of the parts that I needed for this swap, I bought from members on this site. Thanks again to all the members that sold me the parts to do it.
78 Malibu
355/T5 & 3.73's
MalibuRacing.com October 2010 "Malibu of the Month"
SLICK78
Re: B-Pillar conversion, Landau to standard pics
Post by SLICK78 » Wed Oct 13, 2010 7:25 am
man this is awesome thanks for posting it up!
~Charlie~78 landau coupe frame off resto-mod begun to be turbo LSX powered :shock: :twisted:
appsk8r
Post by appsk8r » Wed Oct 13, 2010 8:02 am
wow I didn't realize it took all that work. If you never told me it was a conversion I never would have been able to tell. This is a great how-to, and I've seen it up close and compared it to my original Classic B-pillar and yours looks factory. Nice job.
Click here for pics.
80Grand_LeMans
Post by 80Grand_LeMans » Wed Oct 13, 2010 9:01 am
That came out really nice. I would be scared to do that, lol.
1980 Pontiac Grand LeMans
-Mild Olds 350, TH350, 7.5 one tire fire :(
Post by Doober » Wed Oct 13, 2010 9:38 am
Good pics/info... I'm planning on doing this with the '78 since the top is gone.
MR.com Facebook page
'87 Fiero GT - 2.8/5-speed
nillabu
Post by nillabu » Wed Oct 13, 2010 10:06 am
Great job Bill putting that together! It's a challenge but well worth the finished conversion. Great looking Malibu!!
Steve
80 Malibu/Ex-Landau/Rotisserie Resto
Mild 383 w/200R4-C/K Specs-C/K D5 Medium Stall Lockup
9" w/3.73's & 11" Disc
12" B-Body Spindle/Brake Swap & Rear Frame Notch
Jeep steering shaft up-grade-Narrowed & Rechromed Bumpers
17"x7"-8" TT2's w/BF Goodrich G Force Sports 225/50/4.75" BS-255/45/4" BS
Ya gotta be lost to find a place thats never been found
Bill in NC
Post by Bill in NC » Wed Oct 13, 2010 6:13 pm
Thanks everybody! The pictures make it look way more complicated than it is. If you have everything to do it there, and have no rust issues (lucky me), you could do the swap easily in a day. After the adhesive cures for a day or so, you can easily cut off any excess that may have squeezed out and install the outside trim. Way easier than cleaning off the adhesive while it's still wet. That stuff gets everywhere quick and takes forever to get off your hands.
appsk8r, tell the wife I said thanks again for the tip on the Classic b-pillar trim. She was the one who recommended them and remembered how it wrapped around the pillars on your car.
78 Malibu
355/T5 & 3.73's
SLICK78
Post by SLICK78 » Wed Oct 13, 2010 7:41 pm
h3ll yea thats cool my wife wouldnt notice that I did this conversion if I didnt tell her EVER lol
appsk8r
Re: How To: Landau to standard B-Pillar conversion with pic
Post by appsk8r » Wed Oct 13, 2010 8:07 pm
lol, I didn't know she noticed. She acts like she doesn't know anything about cars sometimes, but she knows more than I give her credit for.
Post by Doober » Wed Oct 13, 2010 9:04 pm
She is definitely a keeper! \:D/
MALObu
Post by MALObu » Thu Oct 14, 2010 12:11 am
man please tell me you kept all the old landau parts?! im gonna be fabing some t-tops into a 79 malibu,and in order to do this i need the landau parts,being that i cant do it on a regular malibu(need the extra space in the pillars) if you have the parts how much would you be asking?
Bill in NC
Post by Bill in NC » Thu Oct 14, 2010 9:41 am
The only parts that I have left from this swap are the lower sail panels and the outside wide Landau chrome b-pillar trim. Everything else was damaged during removal.
78 Malibu
355/T5 & 3.73's
MALObu
Post by MALObu » Thu Oct 14, 2010 9:54 pm
damit!!! gota find me a landau 8-[ thanks.
SLICK78
Post by SLICK78 » Fri Oct 15, 2010 8:46 am
MALObu wrote:damit!!! gota find me a landau 8-[ thanks.
send me your non landau parts and I will send you my landau parts :D
Brown_Gbody
Post by Brown_Gbody » Fri Oct 15, 2010 9:06 am
Nice write up... very informative.
2015 Chevrolet Volt
2005 Lexus LS430
1980 Malibu Classic
Post Reply
