Park your car and talk with other G-Body owners about automotive related topics.
Moderator: Moderators
malibuguy
Re: What did U do to your G-body today??
Post by malibuguy » Sat Jul 18, 2015 7:26 am
I think this carb was originally from a boat. Its weird.
The lockup on my car was thru the ecu and triggered by a signal from the speedo. I have not wired it up yet, when i do ill take pics for sure.
Got the car out last night. Took some fiddling on the carb and timing. Its not 100% but its pretty good.
-Greg...the Exhaust Guy.
--'84 Bonneville...
Past Malibus,
-79 Malibu 4dr
-79 Malibu 2dr
-80 Malibu 4dr
-79 Malibu 4dr
-83 Malibu 4dr
Post by Doober » Sat Jul 18, 2015 3:17 pm
Nothing, but I've been toying with the idea of finding a El Camino out here to replace my rusty '92 full size pickup... transfer the drivetrain from it, rebuild the suspension/body bushings and call it a daily driver.
MR.com Facebook page
'87 Fiero GT - 2.8/5-speed
StreetBu
Post by StreetBu » Sat Jul 18, 2015 7:37 pm
Doober, finish one project before you start another!
'78 bu, 350/380hp, M-21. Now with a GN 3.42 rear and Detroit Tru-Trac, 18x9.5" wheels on all four corners with 275/35/18's, grey bucket seat Monte interior
Post by Doober » Sun Jul 19, 2015 12:11 am
I know, right? :D The truck is kind of another project, was driveable, etc. until the trans gave out, need to rebuild it and address some suspension/steering before anything else on it. The Malibu still has a ways to go.
Tim
Post by Tim » Tue Jul 21, 2015 11:33 am
Last night I modified my 7.5 Gov Lock Posi to a LSD by following this link
http://www.s10forum.com/forum/f13/from- ... si-507016/" onclick="window.open(this.href);return false;
I used a 8.8 forf posi S spring and have over 150ft/lbs breakaway torque. Should be good for drag racing but it may chatter around the city. Will soon find out lol.
V8 Rumble
Post by V8 Rumble » Sat Jul 25, 2015 6:34 am
I put in a camaro monsoon radio last night.
1981Regal
Post by 1981Regal » Sat Jul 25, 2015 8:31 am
What year radio bezel is that? Or did you cut it?
1980 Malibu coupe 468/th350
V8 Rumble
Post by V8 Rumble » Sat Jul 25, 2015 8:57 am
The bezel came out fro the later montes. They already have the 1.5 din opening no cutting at all. The trim actually goes over the Hvac radio opening instead of recessed like the original one.
This is the piece I have but I got it at a junk yard.
http://www.mikesmontes.com/1986-88-Mont ... p_131.html" onclick="window.open(this.href);return false;
1981Regal
Post by 1981Regal » Sat Jul 25, 2015 10:18 am
I'm upgrading a little bit to the 1.5 din style radio. Need something a little newer than the two knob.
V8 Rumble
Post by V8 Rumble » Sat Jul 25, 2015 12:35 pm
Literally just installed my umi rear shock brace
1981Regal
Post by 1981Regal » Sat Jul 25, 2015 1:04 pm
Looks good. Wonder if you will be able feel a difference?
V8 Rumble
Post by V8 Rumble » Sat Jul 25, 2015 2:43 pm
I'm sure it'll tighten up the frame even if it's something I won't feel directly.
78elk
Post by 78elk » Sun Jul 26, 2015 7:46 pm
I reinstalled the plastic trim and seats in the interior. Plastic trim is all the trim around the door.
78elk
Post by 78elk » Mon Jul 27, 2015 7:07 pm
I put some body filler on 2 low spots. Also making hood adjustments, trying to get it level with passenger fender. Made a little progress with the adjustment. Need to give it more thought before I proceed.
78elk
Post by 78elk » Tue Jul 28, 2015 4:53 pm
I started block sanding the Elk.
Post Reply
