Putting this up to help anyone looking for 'em
It's out of my '78 Chevrolet passenger car repair manual, but the specs probably apply for most G-Bodies.
Disclaimer: If you break your bolts it's not my fault
:lol:
Front Suspension
Rear Suspension
Front Suspension
- Ball joint stud nuts
- Upper stud - 60 lb. ft.
- Lower stud - 83 lb. ft.
- Joint to upper arm (bolt-in service replacement)
- 10 lb. ft.
- Control arm pivot to frame
- Upper - 46 lb. ft.
- Lower (nut only) - 62 lb. ft.
- Shock absorber
- Upper end - 90 lb. in.
- Lower end - 20 lb. ft.
- Stabilizer bar
- Link nuts - 150 lb. in.
- Bracket bolts - 24 lb. ft.
- Caliper bolts
- 35 lb. ft.
Rear Suspension
- Upper control arm
- Front bushing nut - 70 lb. ft.
- Rear bushing nut - 73 lb. ft.
- Front bushing bolt - 70 lb. ft.
- Rear bushing bolt - 80 lb. ft.
- Lower control arm
- Rear bushing nut - blank (70-73 lb. ft.???)
- Rear bushing bolt - 73 lb. ft.
- Shock absorber
- Lower nut - 62 lb. ft.
- Upper nut - 12 lb. ft.
- Upper bolt - 20 lb. ft.
- Pinion nose bumper
- 8 lb. ft.
- Stabilizer mounting bracket to control arm
- 35 lb. ft.
