Transmission cooling line attachment
Questions, answers, tips and tech on drivetrain issues.
Moderator: Moderators
Post Reply
78elk
Post by 78elk » Sun Aug 11, 2019 10:53 am
I put in a used 2004r transmission awhile back. The cooling lines where attached to the Radiator. I know 1 line is sending fluid to cool it and the other to return it to the transmission. Where should the return line connect on radiator and transmission?
TURNA
Re: Transmission cooling line attachment
Post by TURNA » Fri Aug 16, 2019 4:25 pm
The bottom cooling line on the 2004r hooks up the the top of the radiator cooling tank
1980 Malibu BBC T-56 9"
1986 Oldsmobile Cutlass.
78elk
Post by 78elk » Sat Aug 17, 2019 1:43 pm
Thank you. Is the bottom line the cooler cooler line?
78elk
Post by 78elk » Wed Aug 21, 2019 1:04 pm
I'm adding a 2004 Cadillac transmission cooler. It has a thermostat that has to be put in with the flow direction. I want to make sure I put it in correctly.
Post Reply
