    Rear Axle Codes
    Here is a table that gives the codes for different rear axle ratio, differential type, manufacturer, and build date information.  THe code is stamped on the right axle tube (as viewed from the front of the car) on the forward side.  It’s tough to see when it’s still in the car.  Of course some of the engine/tranny combinations listed were not available on the 78-83 Malibu.  But this will aid you in finding a rearend to swap into your Malibu.
    The first 3 digits indicate the axle code, the next one indicates manufacturer (B=Buick, O=Olds, C=Chevy, P=Pontiac), the next is Julian date it was built and the last it the shift it was made on. Limited slip rears had a tag on the differential cover that stated it needs posi fluid… that’s usually missing, if the cover has ever been off. However, a “B” in the axle code (i.e., 2BX) usually indicates a posi.
    The 7.5″ rears have a differential cover that is smooth and kind of a squared off oval shape. The 8.5″ rears have a rounder shaped cover with a raisedhorizontal area in the middle.
    1978
    TransEngineRatioPeg LegLtd SlipStd/Opt
    THM350196 “C”
    49 State
    2.732AB2BBSTD
    THM350231 “A” Cal
    49 State
    2.732AB2BBSTD
    THM350231 “A”
    49 State
    3.232AD2BDOPT
    THM350231 “A”
    49 State
    2.412AJ2BJOPT
    THM350231 “A”
    Hi Altitude
    3.232AD2BDSTD
    THM350231 “G”
    49 State
    2.732AB2BBSTD
    THM350231 “3”
    49 State
    2.732AB2BBSTD
    Gear
    Ratio
    Ring
    Gear
    Assembly Codes
    2.417.5″AZ, BZ
    2.567.5″RY, SY, RC, SC, AA, BA
    2.737.5″AX, BX, RS, SX, RD, SD, AB, BB
    2.937.5″AG, BG
    3.237.5″RU, SU, AU, BU, RG, SG
    1979
    THM3503.8 (LD5) A2.412AJ2BJSTD
    THM3503.8 (LD5) A2.732AB2BBOPT
    THM3503.8 (LD5) A3.232AD2BDOPT
    THM3503.8 (LD5)
    High Alt
    3.232AD2BDSTD
    THM3503.8 (LD5) A2.732RX2BXSTD
    THM3503.8 (LD5) A3.232AU2BUOPT
    THM3503.8 (LD5) A
    Calif
    3.232AU2BUOPT
    THM3503.8 (LC6) 2
    Calif
    2.732AB2BBSTD
    THM3503.8 (LC6) 2
    Calif
    2.732RX2BXSTD
    THM3503.8 (LC8) 32.412AJ2BJSTD
    THM3503.8 (LC8) 32.732AB2BBOPT
    THM3503.8 (LC8) 33.082AC—OPT
    THM3503.8 (LC8) 3
    Calif
    2.732AB2BBSTD
    Gear
    Ratio
    Ring
    Gear
    Assembly Codes
    2.147.5″RH
    2.297.5″RA, AH, BH, AT, BT
    2.417.5″AJ, BJ, AZ, BZ
    2.567.5″RC, AA, BA, AY, BY
    2.737.5″AX, BX, RX, RD, AB, BB
    2.937.5″AG, BG
    3.087.5″AC, BC
    3.237.5″AD, BD, SC, RU, AU, BU, RG
    1980
    THM3503.8 (LC8) 32.416RB6BJSTD
    THM3503.8 (LC8) 32.736AB6BBOPT
    THM3503.8 (LC8) 32.736RD6BBSTD
    THM3503.8 (LC8) 33.086AC—OPT
    THM3503.8 (LC8) 3
    Calif
    2.736AB6BBSTD
    Gear
    Ratio
    Ring
    Gear
    Assembly Codes
    2.297.5″AH, BH, AT, BT
    2.567.5″AY, BY
    2.737.5″AX, BX, RX, AB, BB
    2.937.5″AG, BG, AW, BW
    3.087.5″AC, BC, AV
    3.237.5″AU, BU
    1981
    M64/Man 33.8 (LD5)3.088AC8BCSTD
    2.418AJ8BJSTD
    MX2/350C3.8 (LD5)3.088AC8BCOPT
    3.238AD8BDOPT
    MX2/350C
    M33/350
    3.8 (LC8)2.738AB8BBSTD
    3.088AC8BCOPT
    MV9/200C4.3 (LS5) Diesel2.298AH8BHSTD
    Gear
    Ratio
    Ring
    Gear
    Assembly Codes
    2.297.5″AH, AT, BH, BT
    2.417.5″BJ, AJ, BZ, AZ
    2.567.5″BY, AY
    2.737.5″AB, BB, AX, BX, RX
    3.087.5″AC, AV, BC
    3.237.5″AU, BU
    1982
    2.412AJ2BJSTD
    MX2/350C
    M31/250C
    3.8 (LD5)3.082AC2BCOPT
    3.232AD2BDOPT
    MX2/350C3.8 (LC8)3.082AC2BCSTD
    MX2/350C4.1 (LC4)2.412AJ2BJSTD
    MV4/350C
    MV2/350C
    5.7 (LF9)2.292AH2BHSTD
    MV4/350C
    MV2/350C
    4.3 (LT6)
    Diesel
    2.412AJ2BJSTD
    2.562AA2BAHi Alt STD
    Gear
    Ratio
    Ring
    Gear
    Assembly Codes
    2.417.5″BJ, AJ, BZ, AZ, BM, AM, CC, CQ, RZ, CU, RB, CH
    2.567.5″BY, AY, CE, CN, CI, CV, BA, AA, RC, CL, CY, RY, RD, CM, CZ
    2.737.5″AB, BL, AL, AX, BX, CW, CD, CR, BB, RX, CJ
    2.937.5″AG, BG, AW, BW, RW
    3.087.5″AC, BC, AV, RF, RV, BV
    3.237.5″AD, BD, AU, BU, RG, RU, AE, BE
    1983
    2.412AJ2BJSTD
    MX2/350C
    M31/250C
    3.232AD2BDOPT
    MV4/350C
    MV2/350C
    MV4/350C
    MV2/350C
    4.3 (LT6)
    Diesel
    2.412AJ2BJSTD
    Gear
    Ratio
    Ring
    Gear
    Assembly Codes
    2.417.5″RB, CC, AJ, AM, BM, CG, BJ, RZ, CH, AZ, BZ, CU, CK, CX
    2.567.5″RC, CE, AA, CN, BA, CI, AY, CV, BY, RY, CL, CY
    2.737.5″RD, CD, AB, AL, BL, CR, BB, RX, CJ, AX, CW, BX, CM, CZ
    2.937.5″RE, AG, BG, RW, AW, BW
    3.087.5″RF, AC, BC, RV, AV, BV
    3.237.5″RG, AD, BD, RU, AU, BU
    3.427.5″AE, RK, BE
    3.737.5″AF, BF
