Help 10 Bolt 8.5” ring and pinion pattern
mechanicmangg
11
Has been a minute since my last rear gear setup, and Im having a brain fart.
Do you all see any issue with this gear mesh setup?
It is going to be a street with occasional abuse. 😬
Reused the factory pinion shim which is .036
Everything else is new.
Back lash is at .009
3.55 US Gear.
Thanks
mechanicmangg
11
What do you think about this pattern?
4,665
32
The new pattern looks like the old pattern.
How much smaller of a pinion shim did you use?
Do you have the ability to measure the pinion depth, and compare to the markings on the new pinion gear?
I hope someone else chimes in.
mechanicmangg
11
Yes, I do have the T&D Machine pinion depth tool and the Ratech pinion tool.
Both showed I needed a .011 pinion shim.
I use the .011 shim and I get a heel and toe contact.
Each time with a .009 back lash.
Have never had an issue like this before.
Have taken it apart and back together so many times.
And for some reason I cant seem to get a center drive and coast pattern. IDK...
4,665
32
The T&D Machine tool should be good. The Ratech tool is not so good.
Are you using the same bearings to measure the depth and view the wear pattern? I don't agree with the use of setup bearings.
As the pattern seems to be centered between heel and toe, you may be OK as is.
