17x9 with 275 on the front
malibu795
1,497
4
spgfd ohio
mines not lowered and yours is some 3-4"?
i have 175lbin 2.5" coil overs in the back as well the wheel well centers are level in if not racked forward just a bitt
StreetBu
4,158
3
Upstate NY
Yep, the lowest point on the front of my car is the crossmember under the oil pan Hahaha
malibu795
1,497
4
spgfd ohio
my exhaust tube hang below the cross member
need to get some heddman 68610 shorties installed
malibu795
1,497
4
spgfd ohio
put the 275s on the back with 7/32" spacers looks better, and not near the understeer it had with them on the front...and a wash today. definitely some room for 315/35/17 in the back..:D
yeah it needs a frame off :(
Sweet. Mine sits low like StreetBu's, and I think the lowering spindles on mine pushed the wheels out some, probably why they stuck out like they did.
When I had 17s, the fender lip would touch the tire if I bounced the suspension, but they cleared the frame fine (275/40/17 on 17x9.5). If I buuld another chassis to go under this I will either do a custom frame section or notch it to fit something wide like a 315 or 325.
malibu795
1,497
4
spgfd ohio
i dont plan on lowering the car... i need the clearance lol
malibu795
1,497
4
spgfd ohio
dont mind the dirt... got it washed but ran out of light...
trimmed both sides
malibu795
1,497
4
spgfd ohio
Doober said:
Soooo what's the suspension like on the front?
OEM stamped steel with poly bushings and 5608 springs 424lbin rate
malibu795
1,497
4
spgfd ohio
upper BJs are dead... so no alignment
