1978 cutlass original 5 speed
klopper92
New Member
Jan 17, 2007
4
greer south carolina
ok so my dad has a 78 cutlass salon with the original 5 speed. it is a borg warner t50 unit which is locked in third gear. i am wondering how rare this car is and if there is anyone out there that provides parts for that particular trans. i was going to use the trans in another project car but need a few parts for it. but from my searching on the internet have realized that there are very few manual trans g bodys out there. does anyone have any info bout these cars or if its worth restoring or should we just part it out.
Killerdave8813
885
Cincinnati,Ohio
I don't know what a Salon is,rear wheel drive or front? If it's a cool car (rear drive) it's worth restoring,repairing or playing with,very few manual trans G-bodies? I have two,Malibus actualy,one factory and one conversion and there are bunches more out there,T50 trans is a paperweight and that is being very kind,you can probably find parts and repair it but any kind of performance driving and you'll just break it again,there are plenty of alternatives,T5,Tremec,T56,Muncies & T10 four speeds,It just depends on what you want to do! KillerDave
4,387
It only came behind the 260 Olds engine in the Cutlass, so it should last when repaired. I would suggest keeping the car original since it is not a common package. It is the same transmission used in the Cosworth Vega as well as Monzas and related H bodies, though the internal gear ratios may be different.
klopper92
New Member
Jan 17, 2007
4
heres a few shots of it i took with my cell a while back. u are correct that it has the 260 engine. it also had a peg leg 2.56 10 bolt so im gonna assume that first gear in the trans is very low to get the car moving.
Killerdave8813
885
Cincinnati,Ohio
Cool,That's one of those Buttless Cutlasses they were talking about on another thread in here!! It ought to be worth messin with if you like it!!
A 1978-80 cutlass cruiser header panel on 1982 cutlass cruiser Autobody/Paint Technical 3
W 1978 malibu Rear window sweeps and vernier moldings!!!!!!!! Autobody/Paint Technical 3
D 1978 Malibu base model cloth seat bottom Interior Tech 3
1 G-Body Weight loss 1978 to 1983 Suspension Technical 2
BoostedbuLQ9 1978 Malibu LS6/4L60E 11.22 @ 119 MPH Video LSx Tech 4
S 1978 Malibu classic Driveshaft length questions Drivetrain Technical 3
B 1978 Malibu engine compartment Cleanup Transmission Technical 2
retiredrich 1978 BU Circuit Electrical/Wiring Technical 4
2 1978 rear end questions/suggestions Drivetrain Technical 4
D 1978 rotors info Suspension Technical 4
BoostedbuLQ9 Project 1978 Malibu LS Swap LQ9/4L60E Pictures 3-7-10 LSx Tech 5
BoostedbuLQ9 Project 1978 Malibu LS6/4L60E @ Atco Raceway (Video) LSx Tech 7
R 1978 malibu spindles Suspension Technical 4
B what is the correct back spacing for my 1978 malibu Drivetrain Technical 5
BoostedbuLQ9 NEW Project 1978 Malibu LQ9/4L65 Swap 4-28-11 Running Again LSx Tech 87
S 1978 Malibu Front Calipers Wheels/Tires/Brakes Technical 0
V Canadian with 82 Cutlass. Introduce Yourself! 10
H bumpers for 79 cutlass 2 door Autobody/Paint Technical 0
7 Front coil overs in gbody cutlass..no travel..help!!! Suspension Technical 11
B 78 cutlass front clip on 82 Autobody/Paint Technical 1
7 cutlass 442 front springs Suspension Technical 4
S 78 cutlass cluster change out Electrical/Wiring Technical 0
45CHI LSX CUTLASS ALMOST DONE LSx Tech 0
S thinking about a 5.3 swap in my cutlass LSx Tech 6
cutlass-388 Suggestions for 6.0 swap into Cutlass LSx Tech 3
45CHI CAM swap LM7 5.3L/TH400 ??s into 86 CUTLASS COUPE LSx Tech 4
S 78 cutlass & 275/60/15s? Wheels/Tires/Brakes Technical 0
G 87 cutlass supreme bbc headers Drivetrain Technical 10
H inner bumpers on 79 cutlass Autobody/Paint Technical 0
V 5.3L G-body Cutlass LSx Tech 3
LWillmann 88 Cutlass fuel system Drivetrain Technical 8
LWillmann 1988 Olds Cutlass column shift linkage Drivetrain Technical 7
4 Battery Dissconect locations? 85 cutlass 442 Electrical/Wiring Technical 0
k9 Cutlass Supreme-Offset motor Drivetrain Technical 2
k9 Header issue-87 Cutlass Drivetrain Technical 4
M Will 86 cutlass electric split bench seats fit in my Malibu Interior Tech 5
80Grand_LeMans Non Gbody Wiring (76 Cutlass) Electrical/Wiring Technical 2
T Stepping up my cutlass...Roll Bar Questions Suspension Technical 6
J Correct cable for TH400 into an 80 Cutlass Transmission Technical 2
Most_Wanted cutlass rear back spacing help Wheels/Tires/Brakes Technical 1
O early model elcamino 8.5 into a 1986 cutlass Drivetrain Technical 5
O ls motor into a 1986 cutlass LSx Tech 2
B 86 cutlass rear end? Drivetrain Technical 4
R cutlass hoods? Autobody/Paint Technical 1
charasmatic What tire fits on a 84 Cutlass Wheels/Tires/Brakes Technical 7
A Rims/Tires on 87'Cutlass Wheels/Tires/Brakes Technical 5
A L92 cutlass SS PICTURES... WITH A/C LSx Tech 16
A LQ9/L92 almost done in cutlass SS LSx Tech 2
B Wheel/Tire fitament on 82 Cutlass Wheels/Tires/Brakes Technical 4
darius smith 87 cutlass wiring Electrical/Wiring Technical 1
Similar threads
