200r4 and column shift
malibuguy
3,775
Finksburg, Md
No slop at all. The bushings are Delrin actually. Very tight feeling. That spacer I had to get separately along with a longer bolt to have the linkage clear the firewall. I also had to trim a screw down as well...I think held something to do with the steering column plate. You can see it in the picture.
1981Regal
1,274
Cincinnati, Ohio
Did the brass spacer come with the kit or did you make it? The one on the colum side that attaches the rod to the transmission.
malibuguy
3,775
Finksburg, Md
I had to buy it separately along with the longer bolt in order to clear the firewall.
MISFITmalibu63
7,163
The Sticks... Tewksbury MA
I'm currently doing this, do you happen to have the part numbers for the lokar parts you used?
malibuguy
3,775
Finksburg, Md
Ill try to dig it up later after work
80ECLT
3,927
Sheboygan Falls, Wisconsin
I have a 4 speed OD column with tilt, and the OD shift indicator for sale from an 86 el camino in case anyone is interested.
malibuguy
3,775
Finksburg, Md
What color is it?
80ECLT
3,927
burgandy.
