S-10 4.3'S NEVER CAME CARB'D Only TBI or CPI. Full size truck 4.3's were all 4bbl 85-86 and TBI 87-95. G-body 4.3's (85-87) were Also TBI. There was never a 2bbl carb'd 4.3. Only 2-injector TBI systems.
You will need to get an aftermarket 4.3 distributor with vacuum advance (dont use a 3.3(200), or 3.8(229) V6 unit, as they are semi even fire, the 4.3 is True even fire and has a specific distributor) Never has the factory made a non computor controlled 4.3 distributor, unless you consider GMPP parts. They offer one and it is big bux! Go on ebay, you will find many aftermarket ones for $109.00 complete.
Use a 85-86 Full size truck 4bbl manifold or get yourself a edelbrock 4bbl manifold. Use a 390 CFM carb. Dont mess with 2bbl carbs or adapters.
You should be in business.
Thinks to remember:
4.3's use a reverse spinning water pump as they came with serpentine belt systems. If you retain your 229's accy drives, you need to run a 229 water pump on the 4.3.
DONT use the 229 distributor. It is not the same firing order as 4.3.
Pm me if you need more info, Im a self proclaimed 4.3 V6 expert! LOL!!
