5.0 tpi/700r4 swap
heavychevy09
green bay, wi
the driveshaft and crossmember i knew about. i forgot about the converter lock up though. thanks
JP86SS
113
N.E. Ohio
www.wideopenwest.com
Check that there is a speedo cable output on the trans. some only had electrical output.
The dual unit is great in case you ever want to go EFI in the future cuz you'll need to feed the signal to the ECM.
Might as well check that the speed gears are correct before putting it in too.
Allot easier on the floor than under the car.
