it depends on what kind of tires you plan to run, a 5" backspace wheel will clear the frame technically (it's what I run 18x10 w/5" bs) but if you plan on using a tire with any sidewall bulge at all forget it lol
Technically does that still give your rim to frame the needed clearance to go side to side (play in bushings) like when taking a curve, sharp turn, normal everyday driving with angles into parking lots, ect.?
