70 Chevelle 10 bolt 8.2 or 8.5?
DennyPett
543
Spring Hill, Tennessee
Any way to tell the differance between the 8.2 and 8.5 A-Body rears from the outside, Tube diameter or markings or something? I plan on running a spool and 4.56 or 4.88 gears and found a Chevelle 10 bolt fairly cheap.. Will a 8.5 spool work in the 8.2 housing if it is an 8.2 set up?
bowtie81
5,008
sarnia, ontario canada
Got this website from ls6 tommy
http://www.oldsmobility.com/10bolt-tech.htm
If it's the factory rear, it won't be an 8.2". Chevelles all got 8.5" & 12 bolt rear axles.
DennyPett
543
It's out of a 70 2-dr Malibu 6cly, 3spd car, guy is turning it into an SS 454 Clone, gutting it and selling everything out of it...
kevind
868
Whitley City KY
I probably can get You all kinds of 8.2's for $60 each. The are not near as good as a 8.5 and only a little better than a 7.5. I wouldn't give $200 for 3 of them.
kevind
868
Whitley City KY
I don't think the axles or spool will fit. If You want a 8.5 Chevelle rear I can probably find You one.
DennyPett
543
Talk to me.. I dont care about the diff or gears.. would like it otherwise complete.. gonna run a spool and 4.58 or 5.38 gears.. but only looking for high 10's so the stock axles will be fine...
kevind
868
Whitley City KY
PM sent
