70 Chevelle 10 bolt 8.2 or 8.5?
DennyPett
543
Spring Hill, Tennessee
replied
DennyPett
543
I found a complete 72 Monte Parts car with a 10 bolt for $700 obo... THAT should have the 8.5 in it... Might buuy it pull the rear and completely part it out...
malibulvr
1,929
Pensacola, Fl. 32526
All I can say is check the rear end first. Like I said before, GM started putting the 8.5" 10-bolt in these cars in late '71-'72, BUT...............that doesn't always mean that the original rear end that GM put in the car is still the rear end that is in the car. Some idiot dillweed could have always changed it out for an 8.2" 10-bolt due to breakage or other problems. I bought one from a '72 Monte myself sight unseen for $100 , should have checked it cause it turned out to be a 8.2" 10-bolt. The 8.5" 10-bolt rear ends from early Chevelle/Malibu/Monte's around here have become very hard to find. Honestly I would say that you will probably find a 12-bolt from the early cars much easier than the 8.5" 10-bolt. I see them pretty regular in stock form on craigslist for $250-$300.
Another thing to consider, 8.5" 10-bolt rear ends are plentifull in junk yards/recycling yards (or your local U-pullit yard) for cheap,to fit mid 80's Full size GM Impala, Caprice, Parisienne, Lesabre, etc.... Yes it is way way too long, but if you are gonna build it anyways, cut the axle tubes down to the right length, install Ford ends onto the housing, and put in the right length axles of your choice. For another $100 Speedway disc caliper brackets and new Gbody calipers. Just a thought.
DennyPett
543
I missed a 4.56 geared and spooled 12bolt this weekend for $450... offered dude $500 for it as he was paying the guy he was buying it from.. he told me he already had it sold for $750... I told him thanks but no thanks and walked away...
However, I did buy a 7.5 10 bolt with a 4.10 and posi in it.. Will have $200 in it when all said and done.. I've changed my plans on my build and not going as radical as I was planning, going more budget friendly for now so I can get it on the track this year... plan on running 12.0 or 12.50 index class.. so the 10 bolt will hold up just fine behind a mild small block....
DOUG213XRJ
4,671
West, MI
Car that were origanally fitted with the 8.2
1965-70 Chevy fullsize
1964-72 Chevelle
1967-70 Camaro
1970-72 Nova
Car that were origanally fitted with the 8.5
1971-89 chevy fullsize, some 77-89 came with 7.5
1973-77 Chevelle
1970-81 Camaro
1972-79 nova. Not sure if the latter nova had the 7.5 ?
